hi all,
how to design a closed loop regulated buck converter that can produce a variable output voltage of 0 ~ 10V and is able to supply up to 10A load current at any output voltage?
You may wish to post up any attempts you have made to this question, if you are expecting and help. You might also be advised for the benefit of those not in the know, state what a "closed loop regulated buck converter" is.
It's probably not a good idea to design one with such a wide output voltage range. Unless you have a compelling reason to do so. Switchers work best at the designed fixed output voltages.
Incidentally, I've never seen one with output that goes as low as 0V. If you think about it, it kind of makes sense.
