Regular and Non-Regular Language difference?
zulfi100
Joined Jun 7, 2012
656
Q1. A regular language is any (finite or infinite) set of (finite) strings? True
finite set: L= w | w is a set of 'a's less than 1000
inifinite set L= a^n | n >= 0
Q2. A non-regular language is any (finite or infinite) set of (infinite) strings? True
infinite set L= a^n . b^n | n>=0
finite set L=?
Some body please guide me if the true/false are correct and what is an example of a non-regular language having a finite set of infinite length strings?
Zulfi.
WBahn
Joined Mar 31, 2012
33,319
Q1 is claiming that ANY set of finite strings is a regular language. So if you can find just one set of finite strings that is not a regular language, what does that tell you about the truth of that claim?
Can you think of a string that you know has an infinite number of characters in it? Hint: Math is littered with them.
zulfi100
Joined Jun 7, 2012
656
You have already told me that all finite languages are regular.
So its not possible.
Zulfi.
[/QUOTE]
Set of Even Numbers.
What about Q2.
Zulfi.
WBahn
Joined Mar 31, 2012
33,319
There is a difference between saying that a regular language is a finite set of strings and saying that a finite set of strings is a regular language.
You also still are not grasping the critical distinction between all of the strings in a language being finite strings and the language being a finite language.
The set of Even Number is a set having an infinite number of members, but each member in that set is a finite string.
Can you not think of a single value that cannot be represented using a finite number of digits?
zulfi100
Joined Jun 7, 2012
656
What is the difference? Are both not regular?
[QUOTE
[/QUOTE]
22/7 (irrational numbers)
Zulfi.
WBahn
Joined Mar 31, 2012
33,319
The set of all palindromes is an set of finite length strings. It is not a regular language.
How can 22/7 be an irrational number when, by definition, irrational numbers are those than cannot be written as a ratio of two integers?
