Regenertive breaking duration
electronicsLearner77
Joined May 26, 2012
127
I am referring to mild hybrid vehicles. How long does the regenerative braking work? Whether it is for few seconds, minutes? It does this by negative torque. Can i produce the negative torque and positive torque but still rotate in the same direction as engine? Please advise.
Sensacell
Joined Jun 19, 2012
3,784
The torque can be applied both positive, (driving) or negative, (braking) while the shaft revolves in the same direction.
It depends on the direction of energy flow, either from, or to the motor.
You can proportion either energy flow either way, to control the amount of drive or braking effect.
On a long downhill run, the energy flow could be regenerated for minutes at a time.
BR-549
Joined Sep 22, 2013
4,931
An electric motor can both source and sink torque.
It's an electric current to torque transducer(usually called a motor).....and a torque to electric current transducer(usually called a generator).
It's like a intercom speaker(a regenerative speaker sorta speak)..........it works both ways.
Everything is adjustable and controllable.
