Regarding antenna balun
ATPL
Joined Dec 29, 2023
As per theory, if the turns ratio is the square root of the higher impedance divided by the lower impedance;
Example 300/75 = 4
The square root of 4 is 2
Therefore, two turns of wire should go through the ferrite bead to make a 300 to 75 ohm Balun.
But if we use 7 turns then why performance is better than 2 turns which is 4 times impedance from 75ohm to 300ohm .
Then , as per calculation 75 x square of no. of turns = 75 x 49= approx. 3750 ohm
But Yagi antenna are 300ohm type .
Pl. explain
LowQCab
Joined Nov 6, 2012
5,102
"Performance is better" under what conditions ?
How long is the Coax ?
What type of Coax will be used ?
Have You tested the complete system with a VNA ?
What is the SWR of the complete system ?
Will this system be used for transmitting ?
At what general Frequency ?
