MisterBill2
- Joined Jan 23, 2018
- 28,490
Omron is indeed another good brand. Crydom was specified for production equipment by one of the auto companies we buit machines for. So based on that, and that we never had any failures, I recommended them.Less more information let's get the terms.
This is a typical Reed Switch Note the data sheet specifications as to current handling capability.
This is a typical Reed Relay The reed relay includes a coil and is named a reed relay.
They are not the same. Since you mention Reed Switch those wanting to help will need a data sheet similar to what I linked to.
Also since you mention a 110 VAC 10 Amp load you will need switching at least 20% greater than your max load. Using a simple reed switch magnetically turned On/Off I would apply a low voltage like maybe 12 VDC to your reed switch. I would use an AC SSR with a 3 to 32 volt DC control voltage. Let the reed relay drive the SSR. I can only guess you want to maybe use a low voltage DC to switch a 110 Volt 10 Amp AC load.
Consider also if you were to use a reed relay that if you apply AC to a Reed Relay coil it will be switching at the AC frequency applied.
Typical inexpensive AC SSR using a low DC control voltage. I can't speak for the quality of these imported SSRs, personally I used brands like Omron and other more expensive versions. In closing this will not be as simple as using a few resistors.
Ron
