I am trying to reduce the trigger voltage of a soviet flash, like this one:
The internal schematic is this, a bit different meaning that the trigger closes the contact via a resistor to GND (other designs connect the transformer directly to the GND):
On the hot shoe it has 33v. I found this voltage reduction circuit:
http://www.photomacrography.net/forum/viewtopic.php?p=55625
I have used a MAC97 triac and inserted the circuit like in the picture.
Anode2 of triac at C1, Kathode of Zener before the switch, negative at the GND of the flash. I got 63v on the hot shoe !!!. I connected the negative of the voltage reducer to pin 4 of the flash transformer, but it does not discharge the flash.
Is there something that can be done?
