Bordodynov
- Joined May 20, 2015
- 3,431
Using a two-winding choke can be a good idea (I did not check).
For correct simulation, it is necessary to substitute parasitic parameters (resistances) for transformers and chokes.
Also a disadvantage is the galvanic connection. On the sonic earth are large currents (dozens of amperes), which causes interference.
It should also be taken into account that in a real transformer the coupling factor is less than 1 (there is inductance of the winding dispersion).
Also in this microcircuit the control pulses are not symmetrical (the pulse lengths are different), and this will lead to the bias of the transformer.
At first, I built a transformer without scattering inductors. Then I applied the windings taking into account the parasitic inductance.
This sharply reduced the load capacity of the converter. Substitute the coupling factor K = 0.998.
For proper modeling, it is necessary to use a nonlinear core. While this dramatically slows down the calculation. First, I used a nonlinear core.
And then to speed up the account, I switched to linear. The non-linear core has hysteresis loop parameters and dimensions.
