I have a solar panel that has a 36V output. I'd like to be able to reduce it to 12V so it can be fed into a charge controller connected to a 12V deep cycle battery. Is that feasible, and at reasonable cost. I've attached the specs for the panel.
I see buck converters on Amazon for $20-$30 but there are always a few negative reviews where the item didn't work for long, or in one instance started a fire. I'd like to avoid both of those.
Here's an example:
https://www.amazon.com/Converter-EP...eywords=homelylife+36v&qid=1606911917&sr=8-6#
Thanks.
Richard
Here's an example:
Thanks.
Richard
