recommended pull-up resistor for external inputs
bug13
Joined Feb 13, 2012
2,002
Hi guys
Is there some app note somewhere for calculating pull-up resistor values for external inputs. say for example the external switch is 20 meters in a commercial environment (in a 3V3 or 5V system)
I am also interested in the recommended pull-up resistor value for use in industrial environment.
Thanks guys!
cmartinez
Joined Jan 17, 2007
8,834
Hi guys
Thanks guys!
We need a little more info. Is the external switch mechanical, or solid state? Is it wet or dry contacts?
In any case, you'll most probably need resistors at both sides of the cable you'll be using.
Also, it'll be helpful if you take a look at this link:
https://www.digikey.com/en/articles/techzone/2012/apr/protecting-inputs-in-digital-electronics
35,024
Yes, there is an app note somewhere but it is probably easier to explain it.
You need to calculate the range of resistance, i.e. the minimum and maximum resistance required.
The max resistance = (Vdd - Vhigh) / Ihigh
where,
Vdd = supply voltage
Vhigh is in input logic-high threshold voltage
Ihigh is the input logic-high leakage current
The min resistance = (Vdd - Vlow) / Ilow
where,
Vlow is in input logic-low threshold voltage
Ilow is the driver max output sink current
35,024
For long distances in industrial environments it becomes more critical because you are up against cable resistance and EMI. When switch contacts are involved, you need higher currents, 20mA being a common value.
Hence 20mA in 5V environment would call for 5V/20mA = 250Ω
200Ω or 220Ω pullup would be used.
For 3V environment, this is reduced to 100Ω to 150Ω.
MrSoftware
Joined Oct 29, 2013
2,273
Different devices call for different pull-up values, and even then the values may vary by conditions. For example, I'm working on some I2C stuff today and here is a pull-up resistor chart from one of the devices. Here you can see the pull-up value varies not only by the line capacitance, but also by the data rate. This is just an example of why more details are needed before choosing a pull-up value.
dl324
Joined Mar 30, 2015
18,449
From RCA app note ICAN6602:
EDIT: Realized I didn't include the referenced figures:
It's for interfacing between CMOS and TTL, but the reasoning is similar.
bug13
Joined Feb 13, 2012
2,002
What is a common current(mA) value used in a commercial environment.
35,024
Dry contact switches require a minimum current called "wetting current" sometimes spelled "whetting current".
Again, 4-20mA is common across residential/commercial/industrial applications.
