Recommendations for Power Switch
GoldSonic975
Joined Aug 12, 2017
8
Switch.png I'm looking a power switch with at least a GND and +5v connection, does anyone have any recommendations? I can change the PCB if needed.
If this sounds wired i'm rather new to this and might be wrong
dendad
Joined Feb 20, 2016
4,642
It is unclear what you are after. Is it an actual switch or a PCB library part?
And what is it you are switching?
Why do you need a +5V and ground?
If you have a switch that connects the +5V and GND together as it looks like your PCB item above, the result is smoke!
GoldSonic975
Joined Aug 12, 2017
8
Power.png I am looking for a component for the switch and my PCB was wrong, thank you for pointing that out. The schematic part might make it easier to understand
GoldSonic975
Joined Aug 12, 2017
8
