Beginner question, please bear with me!
I have a miniature receiver that has 4 TTL outputs, each independently triggered by one of 4 channels from a paired transmitter. Each output is TTL and rests low, and is driven high.
I want each TTL output, when set high by the corresponding channel on the TX being heard, to both light an LED and sound a 3V 40mA piezo sounder. One sounder and one LED is dedicated to each TTL RX output. The receiver and transmitter both run on 2 to 3.6V at minimal current. I have a mains powered 3.3V step down supply at 5W for the TX and another for the RX. It would be ideal to use the same supply to drive the piezo sounder and an LED per channel for the receiver.
I am thinking MOSFET to do this but would need a basic schematic with values and a comfortably excessively rated MOSFET part number.
Would anyone be kind enough to help me here please? A concern is any implications in using the same supply for the RX itself and what its TTL outputs drive.
The RX datasheet should be linked here: https://www.rfsolutions.co.uk/downloads/62822381d8de6982DS-ZPT-3.pdf
Thanks.
Thanks.
