reassemble old receiver
amitke
Joined May 12, 2020
hi,I have no knowledge of electronics at all and, I need a bit of help with a really old receiver, that had many features that I didn't need(like cd support) and I decided to reassemble it to a smaller box.after removing every part of it that was obvious that unneeded I got stuck with a still 2 big PCBs.
and it not only big it should be connected in a 90 degrees angle.
before taking apart:
my questions is:
can someone please help me and tell me if I can cut the PCB in the middle? in the blue is the cd controller buttons and I removed all the CDs parts.
The other thing and is more important to me is which cable I need to buy that will let me place the two PCB in a smaller angle.
the pictures of the connector and the PCBs:
a look from inside:
side 1 of the connector with "cn601" is written on it:
side 2 of the connector with "cn101" is written on it:
35,167
Welcome to AAC!
No. You cannot cut the PCB indiscriminately without carefully examining what copper traces will be cut.
How would you know if you are not removing a connection or circuit that is essential to the operation of the remaining part of the receiver?
amitke
Joined May 12, 2020
Welcome to AAC!
Thank you, Yes that's what I thought.
Someone know anything about the cable I need?
The connector I have looks like half a SCART socket
