Hey guys,
I'm running a little 5V motor off a relay module controlled with an STM. When I fire the relay the 16x2 starts freaking out and displaying a bunch of random characters.
I've tried running my "JD-VCC (relay power)" from my +5V of the STM line and a separate 5V line. My motor power is running off a separate 5V line. I've soldered bypass caps on the LCD, across the motor and the uC. I've also put a choke inline with the motor.
When I fire the relay (no load attached) the system works perfectly
If I power the motor w/o using the relay and get the leads all up in my other leads everything's okay.
I'm using shielded cable to the motor and grounding the shield to my CCT ground (not earth ground)
Any shielding / grounding / general help would be much appreciated.
Arduino Relay module
My setup
My setup
