At home I have a water meter that has an LC attached to the rotating dial that measures the water.
The official detection circuit is using a coil to pick up the LC and check its resonance. Thus it is able to count the rotations.
I would like to achieve the same, considering the 'easy way' of a proximity detector does not work.
The meter can be found at honeywell V200P and it lists the detection circuit as the falcon PR6
This states:
The mode of operation relies on the principle of electrical oscillating circuit. This information displays the number of electrical oscillations that exceeds a fixed treshold value. Once the rotating metallized half disc of the water meter register is located under one of the 3 coils of
the Falcon module, the vibration is dampened. As a result of the dampening effect, only a small number of amplitudes exceeds the fixed treshold value. This change is measured and processed by a processor.
This model does not use a metal disk, but the coil and assumed capacitor at the back
OBJECTIVE: to create a circuit and use an ESP8266 (or arduino, 3V3 if possible) to achieve the same effect and report to upstream systems.
Idea so far: connect a coil to an oscillator based on a transistor and trigger the interrupt of the MicroProcessor
Closest circuit found till now: OPAMP LC
I hope you can help me?
I can calculate stuff and know a bit but want to get some direction before spending days in the wrong direction.
PS. My first post on the forum, so bear with me
This states:
