Hey everybody!
I am working with a camera sensor with a very poor documentation.
Right now i have it all wire correctly to my sensor but i wish to change it to a different sensor from the same family of the base ic.
The pinouts list of the original sensor and the new one i wished to use are attached in the jpgs.
The third attachment shows on the left side the pins used in the origin sensor, the lines shows the changes i think should be re wired for the new sensor.
As can see, I'm not sure which pins exactly should replace the XCLK and the VCM_PWDN connections.
Please feel free to give any feedback about it.
And of course, help me if you can and guide me to replace the wire of those to pins.
Thanks everybody!
This is the Origin sensor pinout:
pin 1 - DGND
pin 2 - AF_GND
pin 3 - SDA
pin 4 - AF_ACC2 8V
pin 5 - DOVDD1 8V
pin 6 - SCL
pin 7 - AGND
pin 8 - VCM_PWDN
pin 9 - AVDD2 8V
pin 10 - DVDD1 0V
pin 11 - RESET
pin 12 - STROBE
pin 13 - DGND
pin 14 - XCLK
pin 15 - DGND
pin 16 - MDP3
pin 17 - MDN3
pin 18 - DGND
pin 19 - MDP2
pin 20 - MDN2
pin 21 - DGND
pin 22 - MDP0
pin 23 - MDN0
pin 24 - DGND
pin 25 - MCP
pin 26 - MCN
pin 27 - DGND
pin 28 - MDP1
pin 29 - DGND
pin 30 - MDN1
this is the target sensor pinout:
pin 1 - MCLK
pin 2 - DGND
pin 3 - DATA_P
pin 4 - DATA_N
pin 5 - DGND
pin 6 - DATA1_N
pin 7 - DATA1_P
pin 8 - DGND
pin 9 - CLK_N
pin 10 - CLN_P
pin 11 - DGND
pin 12 - NC
pin 13 - NC
pin 14 - AVDD
pin 15 - AGND
pin 16 - DVDD
pin 17 - DOVDD
pin 18 - DGND
pin 19 - SCL
pin 20 - SDA
pin 21 - RESET
pin 22 - CAM_ID DOVDD
pin 23 - DVDD
pin 24 - DGND
pin 25 - DATA3_P
pin 26 - DATA3_N
pin 27 - DGND
pin 28 - DATA2_N
pin 29 - DATA2_P
pin 30 - DGND
and this are the pins in use and the replacement i thought to use:
origin pin 3 SDA -> target pin 20 SDA
origin pin 6 SCL -> target pin 19 SCL
origin pin 8 VCM_PWDN -> ?
origin pin 11 RESET -> target pin 21 RESET
origin pin 14 XCLK -> ?
origin pin 16 MDP3 -> target pin 25 DATA3_P
origin pin 17 MDN3 -> target pin 26 DATA3_N
origin pin 19 MDP2 -> target pin 29 DATA2_P
origin pin 20 MDN2 -> target pin 28 DATA2_N
origin pin 22 MDP0 -> target pin 3 DATA_P
origin pin 23 MDN0 -> target pin 4 DATA_N
origin pin 25 MCP -> target pin 10 CLN_P
origin pin 26 MCN -> target pin 11 CLN_N
origin pin 28 MDP1 -> target pin 7 DATA1_P
origin pin 29 MDN1 -> target pin 6 DATA1_N
Thanks everybody!
pin 1 - DGND
pin 2 - AF_GND
pin 3 - SDA
pin 4 - AF_ACC2 8V
pin 5 - DOVDD1 8V
pin 6 - SCL
pin 7 - AGND
pin 8 - VCM_PWDN
pin 9 - AVDD2 8V
pin 10 - DVDD1 0V
pin 11 - RESET
pin 12 - STROBE
pin 13 - DGND
pin 14 - XCLK
pin 15 - DGND
pin 16 - MDP3
pin 17 - MDN3
pin 18 - DGND
pin 19 - MDP2
pin 20 - MDN2
pin 21 - DGND
pin 22 - MDP0
pin 23 - MDN0
pin 24 - DGND
pin 25 - MCP
pin 26 - MCN
pin 27 - DGND
pin 28 - MDP1
pin 29 - DGND
pin 30 - MDN1
pin 1 - MCLK
pin 2 - DGND
pin 3 - DATA_P
pin 4 - DATA_N
pin 5 - DGND
pin 6 - DATA1_N
pin 7 - DATA1_P
pin 8 - DGND
pin 9 - CLK_N
pin 10 - CLN_P
pin 11 - DGND
pin 12 - NC
pin 13 - NC
pin 14 - AVDD
pin 15 - AGND
pin 16 - DVDD
pin 17 - DOVDD
pin 18 - DGND
pin 19 - SCL
pin 20 - SDA
pin 21 - RESET
pin 23 - DVDD
pin 24 - DGND
pin 25 - DATA3_P
pin 26 - DATA3_N
pin 27 - DGND
pin 28 - DATA2_N
pin 29 - DATA2_P
pin 30 - DGND
