RE: PCB to external connection
Dinesh_rd7
Joined Jan 26, 2020
43
I need to connect 5 wire from pcb to outer terminal,
whether soldering the wire is a better method, or is there any other method for connecting the wire with pcb. it should withstand even in hard environmental conditions.
Thanks,
D
jpanhalt
Joined Jan 18, 2008
11,087
I have used, but do not like soldered wires on the PCB to a detached connector. My favorite method a pinheader (guarded or unguarded) on the PCB to socket on cable (or reversed geometry) or an FPC connector on the PCB and FPC cable. You an also use finger contacts on the PCB and an appropriate connector.
KeithWalker
Joined Jul 10, 2017
3,621
The best method of connecting them will depend on what kind of electrical signal or supply the wires are carrying. Can you give a little more information? what does the PCB do? What is the terminal? Are the wires carrying digital, audio or RF signals? What current are the wires carrying? Without this information, we can not recommend the best way to make the connection.
Regards,
Keith
Dinesh_rd7
Joined Jan 26, 2020
43
Regards,
Keith
The wire carry just the voltage upto 10V, my pcb board function is just measuring the speed of a wheel using a sensor.
RobNevada
Joined Jul 29, 2019
66
I would use a Mil Spec connector. I have attached an image of the bulkhead side. This connector is made by Amphenol but you can also use Tyco as they make this type of connector too. I would solder the wiring to the PCB and use a bulkhead mount on the case.
Those are nice but maybe a little overkill for this application.
KeithWalker
Joined Jul 10, 2017
3,621
How long are the wires? Will the three wires carrying the data need to be shielded or twisted pair? We still don't know what the data signal is. It could be a DC level or a full blown fast communications bus. How can we recommend the best connector without knowing?
MaxHeadRoom
Joined Jul 18, 2013
30,850
Thanks,
D
I generally use screw terminals mounted to the PCT board.
If the 'outer terminal' means external to the PCT enclosure then there is a much cheaper plastic version of the $$$MS (military connector) shown earlier in post #8.
These have various pin out numbers and come with strain relief for a flexible cord/cable etc.
If a straight transmission out, then instead of connector, a plastic strain relief is also available.
Max.
RobNevada
Joined Jul 29, 2019
66
The key statement was environmental. This was the reason for the Mil Spec connectors. The plastic versions are crimp pins or solder pins. Water can go through these connectors as they are not waterproof or dustproof.
