RE:FM HETERODYNE TRANSMITTER
NKEONYINYE
Joined Oct 25, 2008
2
Hi Senior Member Bertus
Please,I am was confused at some of the stages as follows:(1) The stage coupled directly to the VFO: Please is this an IF amplifier or a buffer? The limited literatures I have been able to contact show that a VFO's output is coupled to a buffer (unity gain but I calculated the gain of that transistor circuit and got 2.36.(2) Is the last circuit before the PA an RF amplifier? (3) I have not been able to find a 10.7MHz IF transformer but it seems to me that the IF transformer acts as a filter as well as a “coupler”. So can I replace it with a filter circuit and in what way (the circuit diagram)? What effect will it give to the transmitter? (4). I was not able to get a 44.9333MHz crystal but a 47.5MHz crystal. Can I use this and if yes, how can I finally achieve the same 145-146MHz transmission frequency.(5) Please what are the inductance values of the coils (L1-L3 and T3), or, with what wire gauge and core diameter were the turns achieved.
Please the link to the FM heterodyne transmitter I am refering to are as follows: http://forum.allaboutcircuits.com/showthread.php?t=13137&highlight=heterodyne+transmitter
http://web.telia.com/~u85920178/tx/fm-tx1.htm
I sincerely appreciate you all.
bertus
Joined Apr 5, 2008
22,977
Here is the original schematic you are refering to :
In the origenal versrion L1 is tuned round 10.7 Mhz.
This is mixed with 3 X 44.933 ( ca 135 Mhz ) , the result is 145.7 Mhz.
In you case the mixing frequency will be 3 X 47.5 ( ca. 142.5 Mhz ).
To get in the 144 - 146 range the oscillator must be 1.5 Mhz - 3.5 Mhz.
So you will have to change the circuit round L1 and T1 to get it working.
Greetings,
bertus
Joined Apr 5, 2008
22,977
I have recieved a PM that you can not find some parts.
I think all the parts can be ordered at BOX73 ( www.box73.de ).
They also have the original crystal used in the transmitter.
I have attached a PDF with the RF parts page from the magazine FUNKAMATEUR ( www.funkamateur.de ).
Greetings,
Bretus
