rcwl-0516 motion sensor timing increase please help!
Metalica
Joined Aug 1, 2010
42
When rcwl-0516 detects movement the output pin goes high for around 3 seconds then it goes back to zero please some one guide me how i can increase this time. i mean how to adjust the output timing of this module i want the output to remain high for around 30 seconds when motion is detected ...
if it is possible with the module itself then well n good other wise suggest me a passive circuit for it.
Thank you.
Metalica
Joined Aug 1, 2010
42
bertus
Joined Apr 5, 2008
22,967
The page mentions that the chip is almost identical to the BIsS0001.
On the pins 3 and 4 there is a RC network that makes the output time.
On the board C2 determines the output time.
When you change the capacitor with a 10 times higher value the timing will be 10 times longer.
Bertus
