So how about using a PIR sensor or an RCWL- 0516 sensor with a 5v trigger
relay to work an LED and musical movement driven by a motor?
Motion detector would set the musical movements and LED off. Sadly my 5v timer relay that I have has a constant 4.70v at its TRIG pin out. I was hoping to place my PIN OUT of 3.3v from my sensor onto the relay TRIG pin.
My 5v timer relay has a small black button and when its pressed it will activate the LED and musical movement for 10 seconds. I can adjust the timer with it onboard POT.
Basically I want the motion sensors to activate the relay NOT by me pressing a button.
Any ideas and feedback is greatly appreciated. I am.at the end of my tether with this project.
I never thought that a musical box motion sensor build would be such a headache for me.
relay to work an LED and musical movement driven by a motor?Motion detector would set the musical movements and LED off. Sadly my 5v timer relay that I have has a constant 4.70v at its TRIG pin out. I was hoping to place my PIN OUT of 3.3v from my sensor onto the relay TRIG pin.
