RC Time Constant
sparkie78
Joined Nov 5, 2016
23
I've been reading different articles about oscillators, or more specifically, multivibrators. To find the frequency, you divide 1 by the time constant of RC. I thought the formula for the time constant was simply R x C. But some articles said it was 2.2 x R x C or 2.3 x R x C or .693 x R x C or even 2 x pi x R x C. There might be others I haven't come across yet. Can someone explain this to me please? Thanks in advance
SamR
Joined Mar 19, 2019
5,538
The RC time constant t = RC. t is the product from calculating R x C. 5t is the time required to charge a capacitor (or nearly so as theoretically it never fully charges but gets closer and closer).
WBahn
Joined Mar 31, 2012
33,218
Depends entirely on the circuit.
RC is the time constant associated with a resistor and a capacitor (typically in series). When a step change in voltage occurs, the capacitor voltage will go 1/e (where e is Euler's number -- about 2.718), which is about 63%, of the way from it's starting voltage to the voltage it will have eventually.
That time-dependent change in the capacitor voltage can be used in many different ways to create an oscillator.
In a 555 timer, the capacitor voltage changes between Vcc/3 and 2·Vcc/3 but the eventual voltages are 0 V and Vcc, respectively. If you do the math, the number 2.2 pops out.
38,830
Yes the value of the time-constant is fixed, but not the voltage on the RC charge/discharge curve where the multivibrator changes states.
Obviously, changing the tripping point voltage changes the multivibrator period.
For example, the ubiquitous 555, configured as a multi-vibrator, triggers at 1/3 of Vcc to turn on, and 2/3 of Vcc to turn off.
And the charge and discharge time-constants are often different.
So you can use that information, and the RC time-constant curve equation, to determine the on-time and off-time of the output signal.
So there is no one-size-fits-all equation for determining a multivibrators frequency from the RC values.
35,193
Yes, time constant is R x C.
But that is not the same as time delay in a circuit or the reciprocal of frequency.
To find the time delay and hence frequency you need to know what portion of the charging and discharging waveform is being used to switch the ramp. As shown in the example below, T1 and T2 are not necessarily equal and not necessarily equal to R x C.
AnalogKid
Joined Aug 1, 2013
12,280
No. To find the frequency of a continuous waveform such as a sine wave or square wave, you divide 1 by the period of one complete cycle, whatever that may be.
Correct.
Nope. Each of those is a real equation for a particular circuit. Nnone of them is an equation for the time constant, but each of them uses the time constant. Notice that each of the equations has the R-C value multiplied by a constant (2.2, 2.3, ln(2), 6.28). For example, the corner frequency of a single-pole highpass or lowpass filter is
1 / (2 x pi x R x C)
This also is the equation for the frequency of a Wien-bridge oscillator.
There are many different types of circuits that use one or more R-C networks to set the operating frequency in some manner, but that manner is dependent on the operating mode of the circuit.
ak
sparkie78
Joined Nov 5, 2016
23
Correct.
ak
Got it. My mistake was thinking the time constant and the time period were the same thing. Thanks to everyone for their help. I really appreciate it.
