RC Switch Control Troubleshooting
b2386
Joined Feb 9, 2010
16
Hi all,
Attached is a picture of a circuit I am attempting to troubleshoot. This is part of a larger design which will ultimately create a battery-powered yard wagon as a hobby project.
I am using an RC remote to control it, hence the "Receiver" in the diagram. I am programming one of the switches on the RC controller to act as an Emergency Stop in case things go sideways. This particular circuit is intended to control a 36V solenoid, which can open the battery bank and remove all power from the cart electronics.
Starting out, I had just the "Receiver" and the "PWM Switch". However, the PWM Switch is only rated for 30V. The higher volage from the 36V solenoid eventually killed it (I assume) after ~50 or so actuations.
Consequently, I used 12VDC from elsewhere in the wagon to the "PWM Switch" and added the "DC Switch" which is rated for 36VDC.
However, the problem I am seeing is that whenever the "PWM Switch" is actuated, it immediately turns back off. (I don't think it ever completely actuates.) I tried a couple of test cases: 1) When I disconnect the "PWM Switch" from the "DC Switch", the PWM Switch can actuate just fine as expected and 2) When I apply 12VDC from supply to the "DC Switch", the "DC Switch" actuates correctly as well. So both parts seems to be operating correctly in isolation.
It therefore seems the "PWM Switch" does not like something about being connected to the "DC Switch" and the "PWM Switch" simply does not actuate in this case.
Any ideas what may be causing this behavior and how to correct it? Thanks!
b2386
Joined Feb 9, 2010
16
Argh! I swapped back in the original DC switch to take this picture and it is now working as expected. Not sure what's different this time... I'd been messing with it on and off the past couple of days and no luck until now.
I'll post back if something reappears. Thanks all!
28,624
What is not clear to me is what the PWM device is supposed to do for you. I am guessing that the control is to be simply on/off (START/STOP) , and not variable speed. I do not follow wiring photos.
28,624
Since we have no information as to any current being controlled in any segment of the assembly it is not likely that any useful suggestions are possible.
UNLESS some participant has remote mind reading abilities.
sghioto
Joined Dec 31, 2017
8,765
The wiring between the modules is fairly simple.
Apparently the TS figured it out as it's working now.
Probably just a loose connection.
