From that the motor apparently takes about 1.5A.I need to know how many MA the motor takes, the battery is a 500mah and it will fly for around 20 minutes.
Here is the specs on the panels I was gonna use, but if you know of any better ones let me know, thanks...What is the solar panel spec?
The airplane is a cheap very lightweight low powered one. It weighs only 58 grams with its battery and a review shows that it is so underpowered that it can barely fly. 20 minutes is 1/3rd of an hour so it draws about 1500mA! Its battery weighs about 12 grams but a 3.5V solar panel that delivers 1500mA will weigh way too much.
A review shows replacing its motor. It has 3 tiny motors joined together and have a gearbox. Like most cheap small RC airplanes the motors have brushes that soon wear out.
My RC airplanes weigh 80 grams and use a powerful brushless, gearless motor that lasts forever. They fly maneuvers for 6 minutes with a 280mAh/7.4V battery therefore they draw about 2.8A but not at full power continuously.
