Okay thanks , below attached is the picture of the trialsWelcome to AAC, @Binus01
Please show a schematic of your circuit otherwise we would only be guessing.
400MHz is optimistic for an LM358.Hi team,
I am looking for help design an RC phase shift oscillator with a frequency of 400MHz. The simulation on proteus is not showing any waveform. I would appreciate if anyone could assist .Thanks
What size of the op amp would do400MHz is optimistic for an LM358.
Component values suggest about 15kHz.
Generally, op-amps don’t do 400MHz.What size of the op amp would do
At that frequency, any other oscillator would be more appropriate, except, perhaps, a 555.At that frequency a Colpitts or Hartley oscillator design may be more appropriate.
Even then special techniques in design and construction may be required.At that frequency a Colpitts or Hartley oscillator design may be more appropriate.
| Thread starter | Similar threads | Forum | Replies | Date |
Phase shifter | Power Electronics | 7 | |
| K | Possible Reasons for failiure of gate driver in full bridge phase shift converter | Power Electronics | 5 | |
Constant phase shifters | Analog & Mixed-Signal Design | 60 | |
(Co)sine wave generator with phase shift | General Electronics Chat | 56 | |
bjt amp phase shift | Analog & Mixed-Signal Design | 22 |
