RC High Pass Filter
chrisjsmith
Joined Nov 12, 2016
41
I have completed most of the question for the most part. The last 2 questions have caused a little confusion where I'm asked to find the output voltage given the input frequency to be 1.5 Khz and 150 hz + the roll off db per decade.
I found the voltage gain ratio to be 10 but Vo/Vi = 10
but to get the output voltage when I wasn't given the input voltage not sure if i'm to make an assumption
It would be straight forward question if the input voltage was provided. Is there A way to deduce the Vo/Vi values from the Transfer function.
Please guide me
The Electrician
Joined Oct 9, 2007
2,986
but to get the output voltage when I wasn't given the input voltage not sure if i'm to make an assumptionω
I don't understand your confusion here. Vo/Vi is the voltage gain ratio, and it should be 10; what's the problem?
The problem asks "What is the voltage output of the filter...". You pick an arbitrary input voltage (such as 1 volt), and calculate the output voltage for the two given frequencies. Then you can calculate Vo/VI and see if the roll-off rate per decade is as expected.
By the way, when you calculated R1 for a 2500 Hz corner freq, you forgot that ω =2*Pi*f; don't neglect the 2*Pi part.
chrisjsmith
Joined Nov 12, 2016
41
Hello, thanks for pointed that out. My problem was I was uncertain if I had to make the assumption for the input voltage
appreciate the feedback
chrisjsmith
Joined Nov 12, 2016
41
What do you think?
Can you share with me some literature where I can understand filters that incorporate op amps please?
The Electrician
Joined Oct 9, 2007
2,986
What do you think?
The opamp is being used in inverting configuration so the high frequency gain (K) is -10, not +10. This will affect the phase angle.
As for literature, search for "active filters". The Wikipedia page https://en.wikipedia.org/wiki/Active_filter has some references at the bottom of the page.
