Question about cutoff point of 2-transistor high pass filter
macf123
Joined Feb 5, 2023
I'm trying change the cutoff point of a vintage mixer's HPF from 80 Hz to 60 Hz
I have the service manual in front of me and located the high pass section of the schematic (attached below)
I found this excellent link explaining a vey similar configuration here: https://www.electronics-notes.com/a...ransistor/active-high-pass-filter-circuit.php
However the circuit in the mixer has an additional transistor, and the formula from the electronics notes article resulted in a f0 value fo 112, not 80 as it should be.
Could anyone let me know how I might go about calculating the correct value for the 2 transistor HPF, and ultimately adjusting its value from 80 Hz to 60Hz?
38,820
Below is the LTspice simulation of the circuit:
I experimentally tweaked the values of R6 and R7 to give a -3dB gain drop at 60Hz from the passband gain.
Those are not necessarily optimum values.
