RC filter calculations and simulation in Current Sensing
kalemaxon89
Joined Oct 12, 2022
389
In the schematic of the BoostXL-3PhGaN from Texas Instruments, in the current sensing section, there is this output filter that produces the VA signal that will be sent to the microcontroller and you can plot it with oscilloscope etc.
In addition to understanding why it is necessary, I took the opportunity to do some hand and simulated calculations.
Could you kindly check whether or what I did wrong in these calculations?
sorry, C is 33nF !!!!
I would like the calculated data (especially the cutoff frequency and Gdc) to match those simulated on LTSpice
SOLUTION, ERROR FOUND:
MrAl
Joined Jun 17, 2014
13,777
I could not read your handwriting very easily but I did get a similar result of 1191.1Hz. I usually use 16 digits of precision throughout the calculations unless it calls for better.
kalemaxon89
Joined Oct 12, 2022
389
Can I ask you why there is that filter at 1kHz?
Consider that Va (filtered) will be sent to a connector that will be connected to another board containing the uController.
What do you think is the reason?
MrAl
Joined Jun 17, 2014
13,777
As Eric pointed out, it helps to reduce noise due to any switching or irregularities in the armature.
It also averages the output which is not always possible to do in a microcontroller using digital techniques, and attenuates the signal so the microcontroller can handle it.
In many cases we want to regulate the average performance not the instantaneous. Here it looks like it may be part of a speed controller?
kalemaxon89
Joined Oct 12, 2022
389
I think it is definitely strong of a speed controller since it is the current that is elected by the inverter and definitely used within the algorithm
