Thank you sir!
Hi,Hi all,
I Have a basic doubt.
Why do we have 2 different colored (Black and Blue in this example) RAM slots in a Board?
I have seen many boards, where there are 2 different colored RAM slots? What purpose do they serve?
Please explain.
Hi,Normally memory slots are marked on the motherboard, Slot 0, Slot 1, Slot 2, etc. In the manual they would tell you in what order to install the modules. It has been this way since 286 and 386 cpus. This means that colored slots are just pure marketing.
lolHi,
That's not what i have seen in the past with all the MoBo's i have had.
For example, if i had two yellow and two blue then to use two mem packs most effectively i would have to use either the two yellows or the two blues but not one of each. That's because the two yellows (for example) would allow the memory to be accessed faster though interlaced access. That's the way every MoBo was that i ever had that i can remember, and that's at least 6 or more motherboards of various manufacturers like Asus, Gigabyte, BioStar, MSI.
The MoBo manual usually specifies how to get this right, and it's usually color coded, so the coloring is not hype it's useful. If you dont follow the manu however then you could see a hit in performance because the memory manager wont be able to access the memory as fast as possible.
Here is a pic. You can see the ram has been installed in two light blue slots. Asus MoBo. That also means that ram is installed in every other slot so there is better cooling. The two black slots are not being used.
Hi,lol
thanks for purposefully misinterpreting my statement.
I am reading manual for intel d975xbx2 mobo, from 2007-2008 time period, it has colored ram slots (blue and black in case you give a damn about these things). It has Channel A and Channel B. Each channel has DIMM 0 and DIMM 1. Manual says something to effect: place MATCHING ram modules in Channel A DIMM 0 and Channel B DIMM 0. There is also entry for when using nonmatching ram modules. So. The manual tells me what to install where. Do I need colors to follow instructions in the manual? No. Do I need the actual slots color coded? No.
I have to admit. Bright colors on the slots and the led lights do make the inside of the case look pretty. Like I said, pure marketing so that people with certain tastes can spend their money. I have no problem with people spending their money on these thing.
| Thread starter | Similar threads | Forum | Replies | Date |
| R | Just having a bit of a current control problem. | Power Electronics | 57 | |
| Y | I'm having trouble getting a response from A7670 GSM module. | Microcontrollers | 1 |
