MisterBill2
- Joined Jan 23, 2018
- 28,411
If your hand needs to be touching a cable to get a signal in then there is an open connection someplace before that required touch point. It has already been suggested to try the receiver with the antenna connected directly. I think that is the wire that you touch to hear people.Trying to get 7Mhz people communicating but unfortunately getting radio stations :
Not the issue for now..The receiver : antenna to bandpass filter then through Rf amp
Between the filter (for 50 ohm output ) and Rf amp (50 0hm input) is the problem
There's a cable linking the filter to amp input (coupling) capacitor (100nF). My hand has to be touching this cable for there to be sound at the end
Problem is clear??
Please how to fix?
Thanks
There are several possible problems. The RF amplifier may not be amplifying, and it is probably oscillating and that will prevent any chance of getting a signal through. AND, it is very likely that built the way it is, the amplifier is oscillating, and so the amplifier can not possibly provide a signal.
I know that some folks will tell you that long leads going in every direction will work just as good, but for 7MHZ RF that is NOT TRUE,
