Racing Track warning lights
robismod
Joined Sep 22, 2015
468
(Ok, here he comes again with another crazy idea…LOL)
Last night I went to see my 4 year-old grandson “race” his go kart at a local dirt track. ☺
This track is a recent startup by a local family and they’ve been working hard to improve it. During the races between the big boys, I noticed a couple things that I think would be pretty easy improvements—and with today’s tech can be more affordable. First—lighting on the track was pretty dismal. That’s fairly easy—install more lights. Second—the Caution flags. Two guys with flags along the track and the flagger. I’m thinking about some flashing yellow lights on the fencing situated about every 100 feet or so. Hit a switch and turn them on and off. (Much safer way of letting drivers know more quickly.) I’m wondering if some cheap solar fixtures could be used and all triggered wirelessly? I’m sure it can but don’t know enough about what’s available that could make it easier and affordable. (Again, family owned and not a lot of budget so far)
Thanks for any ideas.
Reloadron
Joined Jan 15, 2015
7,957
A Google of 4 Channel wireless relay card will bring up a dozen like suggested above. The ones I have are good for over 300 feet (a football field). They are 12 Volt so a few SLA batteries and you are in business.
Ron
Jerry-Hat-Trick
Joined Aug 31, 2022
852
https://www.amazon.co.uk/QIACHIP-Tr...2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfbXRm&psc=1
These work really well for me. 433MHz is licence free in the UK, other sub gigahertz frequencies elsewhere. There are two modes, toggle mode is probably best for your application, to go on with one button press and go off when you press again. Range best with 17cm straight antennas but the coil antennas supplied may suffice. I’d suggest using rechargeable batteries rather than solar for a more reliable solution
B-JoJo-S
Joined Jan 3, 2026
559
I would think that for the greatest reliability all the caution lights should be hard wired so that when a switch is flipped the lights come on. Otherwise what happens when a stray signal interferes with the lights? What happens if a jet flys overhead and a radio broadcast either turns them on or off?
Years ago I was trying to set up some parkway lights (driveway) and had a remote and a remote receiver. I wanted to test how far from the house I could still control the lights. Several minutes into the testing my neighbor came with his wireless doorbell. Every time I pushed MY button HIS doorbell would ring. He must have thought someone was messing with him until he saw me in the middle of the street pushing a button and correspondingly his doorbell would ring.
I stopped trying to light the lights remotely.
MisterBill2
Joined Jan 23, 2018
28,417
The "big deal" with any, maybe ALL, danger warning systems is what and when. Announcing a hazard when it is not really a hazard will soon result in it being ignored, or at least not being respected. for the Kart track, the level of hazard varies greatly, from debries on the track to a driver falling out during a rollover incident. (Yellow flag versus red flag)
AND nothing gets attention more than a human waving a flag!
You can use a wired 12V system to power amber LED beacons around the track fence. Install multiple flashing lights at regular intervals for full coverage. All lights connect to a single low-voltage circuit for simplicity. A central 12V power supply keeps the system stable and consistent. An automotive flasher module can synchronize all beacon blinking. Wireless RF relay control lets the flagger trigger caution instantly. One button press activates every light around the circuit. This setup improves visibility, response time, and overall race safety.
Ed McGuirk
Joined Mar 30, 2018
14
Is this a venue where the drivers rent carts from the track or do the drivers bring their own carts? I have seen indoor cart tracks where the warning lights are on each cart right on the steering wheel and maybe taillights. More visible lights but need batteries on the carts if they are not electric. It can even include kill switch for red flag emergency.
robismod
Joined Sep 22, 2015
468
They bring their own karts. I believe most are teams. Also, I think this race course is part of a sanctioning body…still learning more about them…
robismod
Joined Sep 22, 2015
468
I’m starting to rethink the details of this project. Reading LOVEFORCIRCUITS comment again (I think he simplified it a little more for my grasp ) as well as the others’ comments, it hit me I think I’m overthinking some. I started searching for Amber LED “flashing”, and then added “synchronized” lights and I’m seeing lots of 12v options that can be wired together and connecting an included sync wire then all would work together. I believe the race flagger in the elevated box dictates the Caution periods so a simple controller that would supply power with the flip of a switch should suffice. And a run of wire from that position to link the lights together might be the costliest part of it…but surely couldn’t be that bad for this small track? (I think 3 wires is all that is needed HOT, GROUND, and SYNC) I believe the wire could be ran along the top of the track fencing so it would be exposed to the weather…
Now—how about getting that 12v from the controller box out to all the individual lights?
I don’t think that individual 12v supplies located at each light would be good…
robismod
Joined Sep 22, 2015
468
Ahhh I’m now seeing that suggestion about running higher voltage down toward all lights, but using a step-down converter to get the 12v to each light…and…maybe this main “trunk” wire will get expensive having to be pretty heavy and go a long distance…possible help to run two trunks from the controller—one to one half of the circle track lights, and another down the other side to the remaining lights? If there was a gap in the two banks say about middle of the loop, would that affect the sync between both light banks?
MisterBill2
Joined Jan 23, 2018
28,417
Adding to what I mentioned in post #6, Safety is Serious business! In my earlier years I have raced go-karts on a dirt track, and actually, years later, even "lead the pack" one time.( Never backed off a bit)
Since the TS is in the USA, there is an additional hazard relative to whatever one adds to improve safety: It might not be enough!
The suggestions are valid, and post #12 asks some good questions. One thought about the wire size is that, for a given power level, the higher the voltage the less current required. So having the amber caution lights be mains voltage devices, either LED or possibly incandescent, will allow thinner copper wire to be used. In addition, possibly higher wattage and brighter so fewer lights might be adequate.
robismod
Joined Sep 22, 2015
468
An update: I reached out to the folks running it with an email. Reply back was appreciative, but they had a system in place, but did say it was hit-or-miss with working periods. I don’t recall seeing any lights when I was there but…we shall see.
MisterBill2
Joined Jan 23, 2018
28,417
Oh WOW!!! A "Hit-or-Miss"hazard warning system!!
THAT might be worse than no system, if drivers assumed that no warning meant no hazard. And it is a serious liability!!
Probably the TS should pass that news back to the track operators.
I recall skiing at a commercial ski hill a while back. Before I could even pay for the pass, I had to sign a paper stating that I was fully aware that downhill skiing is dangerous and hazards are present, and that they were not accountable for any injuries that would happen. I have no issue with that at all.
robismod
Joined Sep 22, 2015
468
Oops…I left out that they still have the flaggers out on the track as well, so if their lights aren’t working they still have them. I’d sure like to know more on the “why they’re not working” when it happens but I have to wrap my brain around the fact that I’m not connected with them so my opinion likely doesn’t matter. But still, it seems to me that’s such an important detail that isn’t getting the attention it should. Who knows, they may have someone on top of it already. I wasn’t able to make it to the last races (every other week schedule) so maybe tonight. They may have them working already and I’m getting my nose out of joint for no reason…lol
robismod
Joined Sep 22, 2015
468
And as usual, thanks to you guys here for indulging me in my continually occurring episodes. I really appreciate the inputs.
MisterBill2
Joined Jan 23, 2018
28,417
One more pesky detail: The lights WILL need to be bright enough to meet safety warning light standards. That means a bit of power (WATTS). No matter what voltage, POWER= Volts x Amps. So the wire size will matter quite a lot. And doing the math early in the project will be important.
Ya’akov
Joined Jan 27, 2019
10,312
I immediately thought of using stack lights—because I always want to use stack lights.
stack light, yay
~20 bucks a pop, this even has a buzzer in it. Unfortunately, this is a case of "cheap, effective, wireless" pick any two then forget it because it can't be done in any *useful* way on the cheap.
But, stack lights! Yay!
Ya’akov
Joined Jan 27, 2019
10,312
to be clear, if a proper investment was made would be easy to create a system that works. But even the most basic operational system would cost quite a bit.
