Racing Track warning lights
robismod
Joined Sep 22, 2015
473
to be clear, if a proper investment was made would be easy to create a system that works. But even the most basic operational system would cost quite a bit.
I think you’d have to see this operation to get a better “feel” of it—it’s been a pretty rag-tag, “backwoods” kind of track in the past and was shut down. It sits not far away from the owner’s house and garage in a decent plot of land. A handful of old lights strung on poles—it was pretty dark the night I was there and wasn’t near enough light for the drivers. (But I understand that a few volunteers got together last week and added several new ones…little by little) Nothing about it fancy or high-dollar. (Yet… here’s hoping )
Add to that I understand the folks that were running it suddenly departed this past weekend. The races went on without much trouble with the help of a few seasoned volunteers. I believe the owner has enlisted the help of a couple of his professional friends so it’ll be interesting to see where it leads now…
B-JoJo-S
Joined Jan 3, 2026
607
One place I worked had a truck horn as the alert signal for start time, break time, lunch, second brake, 15 minutes before end of shift cleanup horn, quitting horn and in the case of an emergency evacuation there was a push button one could press three times to signal to all the need to evacuate the building. My concern with that was that in a noisy shop the horn wasn't always heard by all workers. Three short blasts could go unnoticed. I presented my argument for an automated system that when activates begins blowing the horn in an intermittent pattern and continues to blow until some safety person or fire department (or other qualified entity) shuts it off. It was a simple system consisting of a 12V transformer, single rectifier, automotive turn signal module, automotive lamp and a relay. When switched on 12V rectified powered the lamp and the module. When the lamp lit it also activated a relay. The relay contacts closed and opened a parallel circuit connected to the pushbutton. So anyone who saw a reasonable emergency to evacuate the building could simply activate the switch and then leave the building. The horn would continue to blow until as mentioned above, someone qualified shuts it off when it is determined that either the emergency has passed or there was no emergency.
It was cheap and effective. But the point is that there was good reason for such a system. Even better would have been an automatic fire detection system. But sometimes cheap people don't want to spend lots of money just to keep people safe. It sounds to me like the operators of this track don't exactly have safety high enough on their agenda to make it a priority for a full course caution lamp system. (or full course Race Stop).
You have a few choices: 1) You can find a better place to race but that might cost you more money. 2) you can keep racing there accepting the risks. 3) You can propose a full course warning system and pay for it yourself - or take up a collection from those who race with you. There may be other options as well. But in the end there's little you can do about someone else's property.
28,603
FIVE second blasts on the warning horn, repeated several times, are not likely to be ignored by at least some folks in a shop. AND even the deaf machine operator would probably notice other folks running for the exits. AND, in the llast place I worked that had a full machine shop,,
the fire exit door had a VERY LOUD WARNING SIREN. (that was there to prevent it being used for smokers breaks) THAT siren was much louder than the official fire warning alarm horn.
If you have ever seen the mess left after a powder type fire suppression system is fired in a kitchen, you would understand why folks are reluctant to trigger them. THAT was the reason for also having a "FIRE BUCKET" of SAND present. And why small fires got water thrown on them. SAND, or ground (granulated) SALT wil also smother fires, and salt wil not ruin the steaks. It is possible to brush it off.
robismod
Joined Sep 22, 2015
473
Update: recently, the folks that were running the track suddenly departed. Now I believe the owner of the land and facility has taken over and they’re trying to get all the kinks out. I went again last night. I did see what looked like 4 Federal Amber lights strapped to the fence. I saw them operating a couple times, not sure if it was timely, and then they didn’t work anymore the rest is the night. What I did see wasn’t much output. I’d still like to help but waiting to see how it all shakes out in the near future…
28,603
I suggest a whole lot of caution driving on that track. I HAVE driven fast go-karts on a circle track and a multi-turns "enduro"track. But on those tracks the whole track was constantly visible, and there were no warning lights.
The "big -deal" with a hazard warning system is the assumption that it works!! That is very important to those folks who need to be warned when a hazard situation is present.
robismod
Joined Sep 22, 2015
473
I’m not a racer—Lord knows I’m way too old for that…LOL, but I have an interest in helping folks out when I can. You are spot-on with your remarks…
In this particular case with the two visits I’ve made and watched the racing, I feel like possibly I could help. While I have suggestions for how to make the audience more connected and informed, my first thoughts were the Caution lighting (or lack of it in my first visit, and then seeing a brief bit on my second visit.) Also from my vantage point outside the fence several areas looked dark to my view—but maybe the drivers have better lighting from their view. They have added a few more track lights so they are working at it.
Now, keep in mind I have not communicated with the new track officials/team/owner…yet. Im working toward that now…So at this early point I’m just putting my thoughts together. And I may not have a clue—I’m sure there are dedicated businesses in Karting that probably sell caution period lighting systems. And I’m pretty sure they ain’t the least bit cheap. Maybe the track folks are financially set better than I think. So far I haven’t seen a lot of evidence of that. Plus, we’re a rural area and not a lot of wealth around these parts. The track isn’t much more than a dirt oval with some aging fencing, and a race flagger elevated stand. They do have a decent PA, with good, clear sound and volume. Big plus to me in my audio years.
The amber lights I did see on my last visit came on a couple of times, but didn’t stay on through the period, and I didn’t see them work again. I got close enough to see there were only 4 of them, and didn’t seem very bright. They were Federal units. Pretty pricey from my online looking.
Let me back up a little bit and expand on things “I don’t know”. I’ve looked online quite a bit for any “regulations” or criteria for Caution lighting but have not found anything. I do know they have flag persons on the track—this last visit I believe there were 4 plus the flag tower. And they were equipped with radios. But IMHO, I believe a good 10-12 fence mounted strobe light units would greatly improve the safety aspect—I noticed several times when an incident occurred, it seemed that the drivers had a delayed reaction before they let off the throttle. Strobing lights around the whole circuit would surely Improve that reaction time immensely.
Again, thanks for the suggestions and ideas.
robismod
Joined Sep 22, 2015
473
Update for 7-13-26…
Was able to meet up with gentleman (who turns out is a musical acquaintance) who has been helping with their audio issues. I’m assisting him now with finding better a solution to make the audio stable. Plus, he knows the managing couple well. He has advised them of my idea to help with the caution lights and they welcome it greatly. Currently they are operating the track but with no real profit realized yet, and welcome help.
So, I’m looking forward to putting these lights together and test it out. I’m not made of money (dang it) so I’m trying to keep it cheap.
Remembering the 48v idea, I’m wondering what wire to consider, and then the step-down 12v transformers—guessing maybe 10 or 12.
For the next few days I’ll be focused on helping my buddy solve the audio questions, and hopefully I’ll return fully to this project. Next race is Aug. 11.
28,603
POSSIBLY a AUDIO warning system on the PA speakers might work, but only if the KART DRIVERS can hear it. My last experienc driving KARTS at a commercial track was that they are "rather loud" and quite noisy.
robismod
Joined Sep 22, 2015
473
Ok, back now and digging in. I have the blessings of the owner and managers to try any ideas on the caution lights.
While working over there last week with fixing an audio issue, I saw their current warning system: a small 12v battery located on the floor of the race director’s feet, and a household light switch mounted on the wall above that. Both exposed to the weather. And some jumbled wiring. Yep. It needs a little freshening up. Yep. Start from scratch.
More to come shortly.
robismod
Joined Sep 22, 2015
473
Here is what I’ve found so far at the track—I’ve attached a drawing too:
Power is a 12v lawn battery, and run through a household wall switch for On/Off. I found a lot of deteriorating wiring and some nasty wire nuts. Repaired what I found and got all 4 lights working.
All lights are the Federal LED Beacons (not cheap from what I’ve seen) but two of them are perfect—UltraStar model 252650. They have programmable flash patterns and I was able to set them to a fast strobe rate that was perfect. However, the two across the track were model 251121, and are non-programmable. Currently they are flashing very slow—maybe once every second or two. Literature says they should flash 85/80 double flashes per minute. They are fed by a pair of wires from race director stand across the track and split to each of these two beacons. I measured about 10.5v just before one beacon.
The two beacons that are close to the race director have a separate pair of wires run to each of the two. (Didn’t take a measurement for some reason) but they were bright in good sun, again with great flash rate.
So it appears in the past someone ran straight wires from the battery to the 4 lights, I’d guess they are about 14 or 16 gauge stranded conductors, inside jacket.
For sh*ts and giggles I’ve ordered a couple of off-brand beacons (60 LED) to replace the two back-of-track beacons and see what happens. And also ordered a 250’ roll of 12gauge landscape wiring to experiment with as well…
At this point I’m exploring what they have and if I can add to it—maybe adding some of the LED strobe marker lights I’ve ordered that could be placed in the end turns…
I’ll be back over there tonight for a work session and see what shakes…
Thanks for hanging with me…
28,603
One cautio suggestion: If you are intending to use an actual transformer, with anAC power output, that may not work if the LED lights require DC power. That is, if they have + and - connection markings. Of course I realize that some DC power packs are described as "transformers." ( so we may have two different languages in use here!)
robismod
Joined Sep 22, 2015
473
In my last trip to the track, I started to disconnect the feed to the back 2 beacons (that were flashing very slowly) but as soon as cut one loose, the remaining one had a much better flashing rate. Figured that huh?
My latest thinking is this: I’ve asked for a new outlet to be installed about the middle of the left turn, and an outlet on the back stretch between the two beacons. The right turn has a light pole nearby with an outlet box and they will run me an extension off it to the middle of the turn. So then I’d have much closer power to the four sections (fourth keeping the existing supply in the flagman stand.)
Now I’m thinking that I could use power supplies at these sections. Then the hurdle would be getting the On/Off signal to each section. Relay(s) and trigger wire?
Also, I now have 10 small LED strobing amber marker lights, I’d like to add to the turn sections—about 4 spread in each turn. (These are cheap and I’m sure I’d replace with beefier units soon)
Specs:
Marker lights (4 in each of two turns)
0.2 amps 12v 2.4 watts
Federal Beacon 252650 programmable
1.2 amps at 12.8 volts
Federal 251121 beacon non-programmable
1.8 amps 12volts
2 replacement beacons for the 251121
30 watts each
How about that?
28,603
OK! But with 12 volt lights the system depends on some sort of 12 volt power. That wiring is not a shock hazard, which is a benefit, but a 120 volts mains supply arrangement provides an almost unlimited power source. So the question becomes "how much warning lights power is enough??"
eetech00
Joined Jun 8, 2013
4,751
I think you’ll need to synchronize the flash of the LEDs so they flash at the same rate and at the same time. So whatever you buy will need to have a way to sync the lights.
Or maybe static lights controlled by a single flashing control signal.
panic mode
Joined Oct 10, 2011
5,469
el cheapo forklift beacons like these are 9-24VDC, are waterproof, have 16 flashing patterns that get retained. so all you need is 2-wire running to each of them. turn them all at once and they are synced.
robismod
Joined Sep 22, 2015
473
Let me ask this…most all of these type fixtures specify “12-24v”…what would the benefit be of one over the other?
robismod
Joined Sep 22, 2015
473
Yes my vision had been seeing them all synced together. I haven’t found any of the beacons that had a sync wire, but there are many of the “marker strobe lights” that have a sync wire along with several flash modes. My original thought was using only marker lights around the whole track that synced together. But then I started seeing some specs that detailed only a certain number could be synced together. Plus, after seeing the Federal beacons already there (and they are a very nice piece—expensive too!), I thought why not use them with marker lights to supplement?
robismod
Joined Sep 22, 2015
473
I have a couple of that type ordered and am anxious to see how they perform against the Federal units that are already in place.
robismod
Joined Sep 22, 2015
473
And, since I’ll have 110v outlets in closer proximity to groups of lights, how would I go about turning them on with one switch—a relay, or relays?
