questions about replacing diode
disturbed123
Joined Jun 11, 2020
122
I have one "with" :
hyperfast
600v 8A
average 1.4 max 1.85 V
about 600v it should be equal or bigger right ?
what about 8A ?
and for that average 1.4V and max 1.85
thanks in advance
Ramussons
Joined May 3, 2013
1,571
I have one with :
hyperfast
600v 8A
about 600v it should be equal or bigger right ? Yes
what about 8A ? 8A or better
and for that average 1.4V and max 1.85 Not able to understand this ....
thanks in advance
What about the hyperfast specs?
Can you give us the Make and Model of what you have?
disturbed123
Joined Jun 11, 2020
122
the question is concrete and most general :)
i have byc8-600 and just want to know when i open site of the seller what to apply from filters of the website for what i need.
jpanhalt
Joined Jan 18, 2008
11,087
I have one "with" :
hyperfast
600v 8A
what about 8A ?
thanks in advance
I would not run it constantly at its maximum voltage or current.
Some specifications are based on potential for damage, like reverse conduction across the diode junction or shorting. Other specifications may be based on heat alone, and at the maximum, the device can get quite warm (look at the specifications for a resistor as an example).
disturbed123
Joined Jun 11, 2020
122
ok...explain me with few words the terms :
average forward current - the average current that can flow though the device in forward direction when in scheme ?
what is VFforward voltage ?
Ramussons
Joined May 3, 2013
1,571
I have one "with" :
hyperfast
600v 8A
what about 8A ?
thanks in advance
For a replacement, 600v 8A -> should be same or Higher.
average 1.4 max 1.85 V -> should be same or Lower
This is the Voltage drop across the diode at 8 Amps. It will need a good heat sink.
disturbed123
Joined Jun 11, 2020
122
is it acceptable to replace :
PFR30L45CT
with
30ctq045
2 things that are questioning me are :
30A 45V MOS Schottky Rectifier
SCHOTTKY RECTIFIER
VF@15A Tj=125 C 0.46V
VF@15A TJ=125 C 0.56V
thanks in advance
Wolframore
Joined Jan 21, 2019
2,619
Did the original burn out? What are the originals is the hyperfast or the PFR30L45CT? Schottky diodes have low fwd voltage but isn’t as good for blocking reverse voltage. Without knowing what It’s being used for rectifying can’t answer your question, what’s being rectified? Is is mains?
