I just found this in a schematic i was going through. This is part of the circuit filters a tacho input signal and then passes it on to a micro controller.
The 74HC2G14 is an dual inverting smith trigger (https://www.mouser.com/datasheet/2/302/74HC_HCT2G14-109587.pdf).
I understand why you would use a smith trigger to clean up the signal. I assume the dual trigger use is to negate the inversion of the first trigger. I also see that there is a rc filter between the first and the second smith trigger. But I do not understand why there is a diode bridging R407 there.
Could some one explain this to me?
