ronsimpson
- Joined Oct 7, 2019
- 4,815
The LT3485 has several versions depending on how much current you want to pull. I chose the -3 which is the highest power version. You might want to back down to a low current version.thank you for all the help!!,
The design in the data sheet used a 1:10 transformer and starts with one end on ground. I did not have any of those here. But I have some Coilcraft transformers that have 1:6 turns. (actually 6 coils) The 10:1 is for 300V. You need about 6:1 for 200V.
10:1 is 1 winding with 10 and one winding with 1. We need more like 6 turns and 1 turn but I only have a transformer with a total on 6 windings. There for I made a boost, not a true transformer supply.
Look at the LTspice file. I have some HP2-0083LD transformers. They are very useful when you cannot afford a custom transformer made. The transformers look like this. By parallel and series, the different windings you can make up something useful.
When choosing a transformer There are some things to look for. I chose the HP2 or HPH2 because the HP1 seemed small to me. The IC seems to like 4 to 10uH of inductance on the primary. I don't remember but I think there was about 20Vus on the primary so a 30.8VuS is good. The current using the big -3 part was about 1.4 or 1.5A. Because of you long time between charges you might think about using a low current version on the IC and rethinking about the HP1 transformer.
If you want to build 10,000 then a special transformer is best. But Coilcraft has these every day.
One option is to use a "7808" switching regulator. (less power loss) Then use the regulator on the computer to drop the 8 to 5V.
Run the photo flash IC on 8V or 10V which is it max.
Or use the switching 7805 to run everything. In all cases I think the LT3485-1 uses 1/3 the power and takes 3x longer to charge but might be better in your case.
On the 7805 regulators. It will get hot dropping the voltage down form 24V. For some reason I can't find the part numbers today. But several companies make a switching power supply that is a PWM and plugs in just like a 7805 but it does not burn power. One of the companies is in the picture but that is not the one I usually use.
