Question Re LTSpice Simulation
elec_eng_55
Joined May 13, 2018
214
But the book is saying about peak to peak value
P = (2*3.41V)^2/(8*8Ω) = 726.75mW
For peak value, we will have
P = (Vpk/√2)*(Vpk/√2)/R = (Vpk²/2)/R = V²/2R = 3.41V^2/(2 *8Ω) = 726.75mW
And for the RMS value
P = (2.41V)^2/8Ω = 726mW
As you can see everything is in order.
Where? in these formulas
How can Pout(peak-to-peak) = Pout(peak) = Pout(rms)?
Is peak not equal to 1/2 of peak-to-peak and rms not equal
to peak times 0.707?
Jony130
Joined Feb 17, 2009
5,598
How can Pout(peak-to-peak) = Pout(peak) = Pout(rms)? Is peak not equal to 1/2 of peak-to-peak and rms not equal
I think that you misunderstand the book about the power calculations.
In general, when we are dealing with AC signals we distinguish the power like this:
1)
Instantaneous power p = u*i (power at any instant of time)
2)
Active (real) power P = Vrms*Irms
3)
And reactive, and apparent power. Not important here.
As you can see only Instantaneous power can have a peak value and meaningless RMS value.
So we are only interested in active/real power.
And the book gives you the equation for an active/real power.
P = Vrms*Irms = Vrms^2/R = Vpeak^2/(2R) = Vpeak-to-peak^2/(8R)
Is that clear now?
elec_eng_55
Joined May 13, 2018
214
1)
2)
3)
Is that clear now?
Okay, so Pout(active or real) = 726.75 mW.
The 1.45 W calculated by LTSpice is peak which is useless?
Alec_t
Joined Sep 17, 2013
15,133
Are you calculating the power in just the load RL, or the total power including that dissipated in the emitter resistor as well?
elec_eng_55
Joined May 13, 2018
214
Just in RL. I guess if you include RE then the dissipation would be 1.45W. In the
sim it is using Vout(pk) * RL but it comes up with 1.45W.
Jony130
Joined Feb 17, 2009
5,598
This is the plot of a Instantaneous power p = u*i (power at any instant of time)
To plot the instantaneous power dissipation of a component, hold down the Alt key and click on the body of the symbol of the component. The instantaneous power dissipation will be plotted as an expression of voltages and currents. And to obtain the average and RMS value switch to the waveform then move the mouse to the label of the trace, hold down the control key and left mouse click.
elec_eng_55
Joined May 13, 2018
214
Thanks!
