Question Re LTSpice Simulation
elec_eng_55
Joined May 13, 2018
214
hi, David,
Note the ' mag' in the listing: ie magnitude , peak values.
You can always double check by running a quick .tran
E
Hi Eric:
The sim computes the Pout(pk) = 3.41 V(pk) *424 mA = 1.45 Watts
If you use Pout(pk) = Vout(pk)^2 / 4 * re where re = RE//RL = 4 Ω
Pout(pk) = 3.41 V(pk)^2 / 4 * 4 Ω = 726.376 mW
Pout(ppv) = [Vout(pk) * 2]^2 / 8 * 4 Ω = 1.45 W
That is why I asked this question. I am confused.
David
ericgibbs
Joined Jan 29, 2010
18,862
hi D,
On your asc sim, make the .tran active and run the sim.
Then place the cursor on the emitter resistor, press down the 'Alt' key on the keyboard, the power plot should appear. [click the left mouse key]
To show the power label, place the cursor on power label on the top of the plot screen and press down the Ctrl key.
E
elec_eng_55
Joined May 13, 2018
214
hi D,
E
Thanks Eric.
I am still confused with respect to the formulae. These formulae are taken from
Malvino's text "Electronic Principles" 8th edition. See attached.
eetech00
Joined Jun 8, 2013
3,956
elec_eng_55
Joined May 13, 2018
214
I'm I right to say that you are using AC analysis to determine the peak values?
These formulas should yield the same results as the sim.
The sim says that Pout(pk) = 1.45 W
My question is. Is Pout(pk) = 1.45W or 726.376 mW ?
Jony130
Joined Feb 17, 2009
5,488
As I said you shouldn't use the AC analysis resoults in this case. Only transient analysis is valid in thia case.
And for Vin = 5.07Vpeak the output power is given by LTspice is 715.87mW
elec_eng_55
Joined May 13, 2018
214
But the average power is the "real power".
I get that the real power is the "average".
But what good are the formulas in the text if they don't yield the right value?
In some places they use RL in the denominator and in other places they use re (=RE//RL).
RL is the correct value?
Jony130
Joined Feb 17, 2009
5,488
But the book is saying about peak to peak value
P = (2*3.41V)^2/(8*8Ω) = 726.75mW
For peak value, we will have
P = (Vpk/√2)*(Vpk/√2)/R = (Vpk²/2)/R = V²/2R = 3.41V^2/(2 *8Ω) = 726.75mW
And for the RMS value
P = (2.41V)^2/8Ω = 726mW
As you can see everything is in order.
Where?
Where?
