Question on testing transistor 3904
Rattle49
Joined Sep 22, 2015
3
Hello Everyone,
I am testing transistor 3904 with a digital multimeter. When I put it on diode function the test result was perfect. reads 0.66V and 0.63V. But I also want to be able to use resistance function to test. While my results are around 7 or 8 mega ohms. I thought it should be somewhere around 500 ohms. I am just so confused. Please help........
OBW0549
Joined Mar 2, 2015
3,565
The reason you're not getting the results you expect is that your DMM uses a very low voltage to measure resistance, and this voltage is not enough to forward bias semiconductor junctions and get a meaningful reading. One of my DMMs applies only 400 mV and the other one, only 200 mV. Yours is probably similar.
MikeML
5,444
If your DMM has a diode test mode as one of its Ohmmeter ranges, then it applies sufficient voltage across the device being measured to forward bias a Si junction. Mine even causes a red LED (Vf=~2V) to glow dimly...
Rattle49
Joined Sep 22, 2015
3
Ah that makes sense. Thank you so much
dannyf
Joined Sep 13, 2015
2,197
Why did you think so?
The "resistance" of a p-n junction is a function of the current through it, or alternatively, the voltage across it. Without knowing either of that, it could be anything from 100s of Mohms down to a few ohm.
vk6zgo
Joined Jul 21, 2012
677
It won't give you definitive results like a proper tester,but you can check your NPN BJT for gain with a multimeter.
On "diode test" position,place the red lead on the collector,the black on the emitter.
Now spit on your finger & place it between the base & collector.
The meter will show collector current as a drop in resistance.
This will also work for PNP with the red & black leads transposed.
I mainly use this as a "go/no-go" test,or to determine which lead is the collector on unknown transistors.
A reversed transistor will show lower gain than a correctly connected one.
Rattle49
Joined Sep 22, 2015
3
I read it from a book saying that if you test your transistor with resistance function, "the DMM should read a low forward resistance, typically less than 1kΩ". the figure in the book just shows a DMM with 1 lead on emitter and the other on base.
