Question about voltage input output
Jim Pap
Joined Nov 27, 2020
6
So i have this simple circuit.While my voltage input is 5V why is my output 3.3V? Can someone explain this to me.Thanks in advance!
bertus
Joined Apr 5, 2008
23,014
There is no series resistor for the led.
Put a 470 Ohms resistor in series with the led.
Depending on the type of led, the voltage will be clamped at the forward voltage of the led.
Bertus
Jim Pap
Joined Nov 27, 2020
6
That was the given circuit.Dont mind the led it can be a lamp like here.I just dont understand where 1.7 volts have gone since i have input 5V and i get 3.3.You get me now?
Bertus
hi Jim,
What would you say the LED current level is.??
LED type and operating voltage.?
E
ericgibbs
Joined Jan 29, 2010
21,601
hi,
If you check the data sheet for a typical OR Gate it will give you an idea how much output current can be output from the Gate.
The Gate has an internal resistance
E
bertus
Joined Apr 5, 2008
23,014
I mean the supply voltage of U1 in the simulator, not the input voltages.
How are the supply settings?
Bertus
38,871
As bertus said, without a series resistor, the output is clamped at the forward voltage of the LED which is about 3.3V in the simulator.
The 1.7V is dropped in the gate output resistance.
An LED is a diode (Light Emitting Diode) so has a very low resistance once you reach it's characteristic forward voltage.
It does not act as a resistor the way an incandescent bulb does.
