- Joined Jul 18, 2013
- 30,854
If it is a BLDC (3 wire) then straight DC is not much good, Unless it has an internal controller, you would need to verify just what you have first before trying to control it.Hello. I am found a 3 wire dc motor that is in brand new condition. I tried hooking it up with a dc power source its a dc motor. It has three wires and green black and red. the number ldc on my 36 volt power supply flickers so i think the power cables are not hooked up properly. I know what 3 phase ac motors are and how they work but i do not know much about a 3 wire dc motor. I read around and heard you need a micro controller to control a 3 wire dc motor. Does anyone know how to make a or get a simple controller for one of these motors or anything about them. Thanks.
If you did actually feed it straight DC then I assume you did not use the green wire, which in this case would probably be the GND, again verify resistance to frame.
Also if feeding it straight DC and and it ran and has NO brushes, then it smacks of an internal ECM motor of some kind.
