Hi guys
I have recently built an voltage controlled filter using the schematic from MFOS experimenter board. The circuit consists of a cut off frequency control and a resonance control. The resonance part of the circuit is working fine but I cannot get the cut off control to work at all. The cut off works through a PN4391 transistor set up as a variable resistor and I believe this is the component that isn't functioning as it should. I have checked the circuit over thoroughly and all connections seem to be correct, however when I go through the circuit with a continuity tester the Drain and the Source are connected, and they shouldn't be according to the schematic. So my question is, is this normal behavior for a PN4391 transistor? Unfortunately these transistors are discontinued and are being sold for ridiculous money on ebay. This is where I originally purchased 2 of them (generic brand), and I'm wondering could I have bought 2 dodgy ones as Ray from MFOS says they can vary in characteristics quite a bit.
I have now purchased 1 Fairchild PN4391 from ebay but I am waiting for it to arrive to test it.
schematic: (See schematic in post #3)
Any help with this would be greatly appreciated.
