question about ClassD amplifier
Nykolas
Joined Aug 27, 2013
115
Whatsa 2110? Over 3.3 million entries on Google. Where is the triangular wave? Redraw the schematic so that only the necessary parts are shown, as is it hurts my head. E
bertus
Joined Apr 5, 2008
22,888
@Nykolas , the 2110 mentioned in the schematic looks like a basic halfbridge (high side & low side) driver IR2110.
I also see not where the PWM is generated.
Bertus
ian field
Joined Oct 27, 2012
6,536
Hi everybody
Currently i am having some questions about classD amplifier circuit. This is a diagram of the principle that I have found
http://www.upsieutoc.com/image/In2O2j
but I do not understand where the circuit creates the triangular pulse?
please help me
You'll have to remind me whether the TL071 is single or dual - I'd usually expect one op-amp to be wired as a triangle generator and the other as a comparator..
The comparator compares the signal with the rising and falling triangle and the output is pretty much the M/S ratio.
RichardO
Joined May 4, 2013
2,270
I have not done any serious analysis. But here goes:
There is feedback from the output FET's clear back to the summing input of the op-amp. I am guessing that the RC network in the feedback of the op-amp is causing an oscillation that is compared to the PWM signal from the FET's.
Pretty handwavey, I admit. I am waiting for all of the detailed explanations that prove me wrong. That way I will have learned something. :D
(I am having a hard time keeping from spending a lot of time doing an LTspice simulation of a simplified version of the circuit.)
@ian field : the TL071 is a single.
ian field
Joined Oct 27, 2012
6,536
I caught on a split second after clicking post reply - that's what the final digit means. Its been a while...........
the kid
Joined Jan 4, 2015
82
thank u very much, Here is my picture I found.
but i dont understand how it operate?
the kid
Joined Jan 4, 2015
82
I removed feed back from output and input signal then simulate it on PSIM
how to it oscilate?
everyone help me please
DickCappels
Joined Aug 21, 2008
10,661
It looks like they left a couple of parts off the schematic.
If you add a resistor and capacitor to the 4049 you will make it into an oscillator.
The 2N5401 is connected as a current source that is modulated by the audio from the TL071. Adding this current to an input of the oscillator causes duty cycle modulation.
