Question about blob on IC
danadak
Joined Mar 10, 2018
4,057
Manufacturing process where die were down bonded to pcb and/or substrate
then a glob was dropped on them to make package impervious to environment
like humidity for example.
Regards, Dana.
narkeleptk
Joined Mar 11, 2019
586
you test it at all the little holes around it but you need to figure out whats what first. Easier to test pcb input and output functions and then if fault is found work backwards from there imo. The bubbles are probably just how the blob dried.
Sqweewul
Joined Jul 6, 2019
This circuit is tuner in acoustic guitar. I bought it like 5 years ago, I remember that tuner was working just fine in the shop, after that it doesn't. I guess it will be impossible to find what's not working
