This is the one ...
All the input and output power goes through the circuit , and cells are balanced via the many small wires ...
But in the specifications it just says "Charge voltage 29.2V" ... no further details ! I'm sure if I put 30V it would be OK .... But I want to connect directly to solar panels Open circuit voltage 40V ( they can only deliver max current of 8A@ 30V )... will I blow it ? ...
That little oblong thing on two white wires is a temp sensor I guess ... do I tuck it inside the circuit or in the battery?
Maximum discharge current: 200A
Instantaneous discharge current:500A
Charging voltage: 29.2V
Maximum charging current: 200A
Overcharge detection voltage: 3.75±0.025V
Overcharge protection delay: 100ms
Overcharge release voltage: 3.6±0.05V
Battery balance detection voltage: 3.6±0.025V
Battery balance release voltage: 3.6±0.05V
Battery balance current: 35±5 mA
Overdischarge detection voltage: 2.1 ± 0.08V
Overdischarge detection delay: 100ms
Overdischarge release voltage: 2.3±0.1V
Overcurrent detection voltage: 150mV
Overcurrent detection delay: 10ms
