Question about a rectifier PCB of a welding power supply
BlackMelon
Joined Mar 19, 2015
173
I am converting the aforementioned PCB into a circuit. The relays are marked "RL" and highlighted by corresponding colors: yellow for the contacts and coil of the relay 2, for example. Connectors are represented by open circuits. However, I don't understand how the circuit circled by the red circle works.
To my sense, it is a transient protection system, since it got TVS diodes (KE150CA). However, why do we need D5, since it will make the whole protection system work in only one direction? Also, I don't get the idea of using C5 here too.
Should you provide resources for my further studying, I would be appreciated.
Sincerely,
BlackMelon
AlbertHall
Joined Jun 4, 2014
12,663
There is a contact labelled RL2 but coloured green up near the inductor. Should this be RL4?
What is COM3 connected to?
Maybe they are using the KE150's as 150V zeners, and then together with R4 and C5 may give a delayed turn of RL2
BlackMelon
Joined Mar 19, 2015
173
Do you mean the green contact that is connected to a NTC47-D15 thermistor? If so, that one is RL1. Sorry for my handwriting.
It is wired to a switching board, containing power MOSFETs and also control electronics. I will provide you more detail after I finished drawing the schematic of that board.
Thank you for your advice. If I have any updates, I will let you know here.
Sincerely,
