MisterBill2
- Joined Jan 23, 2018
- 28,139
I suggested the reasonable scheme for doing what the TS requested in post #1, in a manner that will perform reliably, in post #11. That was based on the guess that the system had to be reliable and last for some extended period of time. The interval timer and suitable motor control relay are both made by OMRON, a company with fairly wide distribution, and reasonable prices.
Given, however, that we have no information as to the actual application, which there may be a better scheme to achieve the desired control, such as a level switch or a pressure switch, operation of alternative timers is all that has been suggested.
A 555 could do the job, the capacitor choice is limited to the very low leakage variety of capacitors, and the supply voltage would need to be regulated fairly well.
