Greetings everyone. I'm new to this forum, so please cut me some husk if I screw up. I'm currently learning about antique tube radios and ran across this book titled: Old Time Radios!Restoration and Repair-by Joseph J. Carr. On the workings of vacuum tubes, on the top of page 48,he makes referance to:quasistatic dc and ac process. He is explaining
late resistence and plate impedance. The paragraph reads as follows
late resistance and plate impedance are related terms, but are differant in that one is a quasistatic dc process and the other is an ac process. Plate resistance is defined as: Rp=Vb/Ip. Rp=plate resistance. Vb=plate voltage-dc. Ip=plate current-dc. The second paragragh reads: Plate impedance,on the other hand, is defined in terms of alternating current, so it is a dynamic measure of the same thing. rp=Δvb/Δip(Vc=constant). I forgot. He also gives a formula for grid voltage necessary to effect cutoff: --Vco=Vb/μ. My question is:What is a quasistatic dc and ac process?The only thing I can find on the internet just deals with physics explanations such as refering to entropy and equilibreum of things like cylinder pressure. Any help with this inquiry will be greatly appreciated.
