QSpice weird behavior when outputting a sine wave from c++ to an Op-Amp
YoucefH
Joined Sep 17, 2024
11
That is the opposite of what you said in your original post.
those are two statements about two different tests.
There are three situations here:
1- signal from X1 has a fixed amplitude that goes to the op-amp. the op-amp gives a 5v square wave.
2- signal from X1 has an amplitude that increases over time, and the op-amp gives a normal 5v square wave. what is not normal is that the signal from X1 should only go to about 2v pk-to-pk but instead it goes beyond 800v pk-to-pk.
3- signal from X1 has an amplitude that increases over time to some limit and then it decreases back to 0v but when connected to the op-amp the signal from X1 becomes incorrect and i get a weird signal from the op-amp.
all the images are in the first post.
BobTPH
Joined Jun 5, 2013
11,678
Twice, you said it as the X1 signal that was wrong.
