PWM with adjustable current and voltage
aleaman
Joined Oct 12, 2023
Hello to all,
I have a school project where I need to study the effects of frequency, voltage, and current on an electrolysis cell. I also need to consider the resonance frequency of water, which is 42.8 kHz and its harmonics. So, I would like to build a PWM (Pulse Width Modulation) circuit that can provide pulses at a chosen frequency and allow me to adjust both the current (0-3A) and voltage (0-12V). Can you help me with some advices and a schematic?
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC!
Since this is your school assignment, please post your best effort at a design so that we can give guidance where needed.
aleaman
Joined Oct 12, 2023
I will try,but it takes me too much to find the suitable components. It is better for me too see a scheme and to try to understand how it works. You asked me for a higher level. Thx anyway
Danko
Joined Nov 22, 2017
2,238
I recommend you to read with attention this 3-pages thread:
https://forum.allaboutcircuits.com/...cuit-op-amp-mosfet-driver.166021/post-1464183
It is almost exactly your case, only frequency is 30 kHz.
dcbingaman
Joined Jun 30, 2021
1,065
Hello to all,
What 'chosen' frequencies do you need in your design?
I would recommend starting with a block design. That is create a 'high level' abstraction of the circuit. You can then break the problem down to smaller chunks.
Here is the basic idea:
MrAl
Joined Jun 17, 2014
13,805
Hello to all,
Hello there,
This is interesting, although I have to defer any advice at the moment I will help in the future if I can.
But first, this is interesting because I have never heard about any specific resonant frequency of water, or is it that you are working with a given volume of water for every experiment.
Papabravo
Joined Feb 24, 2006
22,113
Hello there,
I've never heard of a resonance frequency of water either. Can the TS provide any references for this phenomenon?
Ian0
Joined Aug 7, 2020
13,286
Various random places on the internet give it as 1.1x10^14Hz, which for something as titchy as a water molecule sounds an awful lot more likely than 42kHz.
Danko
Joined Nov 22, 2017
2,238
