PWM pump driver, needs feeback to slow pump when supply current falls from PV (with pixs, schematic)
Hamlet
Joined Jun 10, 2015
560
R1 should be able to supply 5 mA for a LED without disturbing the circuit. If ronv concurs, might connect U1 output to the base of an emitter follower like a 2N3904, collector to +12V, & emitter to 2k, other end to LED anode, cathode to ground.
But this won't differentiate between the "pwm state" and the "steady on" state...?
EDIT: If I have an indicator, I can spend some time working with this basic circuit, tuning it for different motors, voltages, loads, etc. Although comparitors & opamps might seem simple to many of you folks, I have very little experience in this area, and so this project seems like a good start for me to familiarize myself with their operation.
ronv
Joined Nov 12, 2008
3,770
Sounds good to me!
Edit:The brightness may vary. Hard to tell how much.
Bernard
Joined Aug 7, 2008
5,784
You could cap. couple a high impedance speaker to emitter , in parallel with R & LED. You can hear a wider range of buzz than the LED can show ??
