PWM pin getting fail in pic18f45k50 when iam trying control the Ceiling Fan .
DickCappels
Joined Aug 21, 2008
10,661
What is "microcontroller PWM"? Is it synchronized with the zero crossings
of the mains per the application note?
While at it, can you expand on wht you mean by "fail"? Do you mean the fan does not even turn on?
bertus
Joined Apr 5, 2008
23,023
Also what is the output voltage of the MCU?
If it is 3.3 Volts, the led will get to less current.
It is recommended to use a drive current of 15 mA for the led in the MOC.
Also you may try to add a snubber circuit as in the application circuit:
Nanda Kumar 1
Joined Aug 25, 2016
42
Thank you for u r reply DickCappels .
1) "Microcontroller pwm" is the signal coming from the micro controller to the MOC3021.
2) No iam not using the zero crossing.
3)fan is running with respect to the pwm duty cycle but after some time that particuler pwm pin coming from the microcontroller pin going fail .That pin is not doing any functionality.
Nanda Kumar 1
Joined Aug 25, 2016
42
m
Thank you for u r reply.
1) My micro controller output is 4.9v .
2) Iam using the snubber RC as 2.2kohms and 0.1 uf.( I uploaded my schematic in above).
Nanda Kumar 1
Joined Aug 25, 2016
42
In the schematic I posted, the 39 Ohm and 10 nF are for snubbing the triac.
It will reduce the dV/dt.
See the attached application note for more info.
Thank you Bertus.
I will try today and what about the traic .can i use any type traic or is there any particuler traic ?.And what about my schematic ? is there any wrong in that because i did as per NXP AN3471 application note.
30,872
The PWM circuit is only going to fire the triac once per AC cycle, and will also vary the point it fires on the AC supply.
IOW it is not sync'ed to the incoming frequency.
