PVT of Switched-Capacitor Voltage Converters
PapsNgBayan
Joined Aug 12, 2018
Hi all, I'm an MS student of Microelectronics and am currently in the process of coming up with a research topic. I've been reading a lot of papers published in IEEE Xplore Library on the topic of SC Converters, and I've noticed that there is not much focus on the PVT variation aspect affecting the converters. I'm not sure if it's because PVT has not been a problem for the block around the 65 nm range given the feedback modulation methods that are usually being applied or if it's an upcoming or future problem that comes with scaling lower and lower into the 28 nm range and smaller. What do you guys think?
